Painting over Duplicolor Primer
I want to spray feather-fill primer surface over duplicolor primer on my frame. Should I strip the dulpicolor primer off, or just spray over it?
Thanks, T-Bucket Bob
Epoxy primer is what I was told and used on all bare metal. But I see etching or epoxy is recommended depending who you talk to. I don't think there is a clear better choice...
There are epoxy self etching primers such as PPG DP-90. That may be what was used. I would ask someone who works where you purchased the primers or will purchase. It's usually best to use products from the same line that are engineered to work together.
