Hi guys,
Just another tyro question...my steering box was mounted so that the output shaft is under the frame pointing out rail and the pitman arm points up. I think it's a vega box.
When I went to mount the arm, I found it would interfere with the radius rod mounts when it went forward (left turn). This can be resolved by rotating the arm to the 2
'o' clock position when the wheel is centered. I tried that and the steering moves smoothly through the range. Is that an O.K. solution, or do I have to find an offset arm so that the arm is vertical at center steering?
Any suggestions would be appreciated...thanks, olguy
