Placement of Motor mounts for Chevy engine
ronhallam
OK, I'm I correct in understanding wether I have a 305 or 350 small block Chevy the motor mounts are the same and the frame mounts will go on the frame in the same location? Tnx, Ron
Ron,
The measurment for small and big block chevys is 15.9 something from the centerline of the 3 bolt mount on the block to the rear of the block (where the trans bellhousing bolts). If you search this site there are some engine charts showing all of the measurements for chevy engines and transmission lengths...Ron(ruggs)
