Something has changed! Previously when I logged in, I would click on "PORTAL" and the page would show several posts (some that I have read and some that I have not). Today when I click on "PORTAL" I get a blank page. Also there is no option on the right side of screen to see active posts. I am using the same search engine and same shortcuts that I did yesterday. WHAT'S GOING ON???????
First off - I had not added any of the content back into the Portal page and was considering its removal. With the exception of the calendar, there is no content there that cannot be found on the forum index page. Since it looks like some of you were using it, the Portal has been restored.
Second - Actually, there is a link for you to select new content.
I can see it plainly, on both the CleanCut 3.1 skin IP.Board . Might I respectfully suggest you have simply overlooked the link? The reason I suggest this is in the issue you submitted to the Support page at 8:15 last evening, you reported the above, plus the fact you could not find a way to post anything to the forum. And then, the issue you submitted to the Support page at 8:16 last evening, you reported the above, plus the fact you could not find a way to post anything to the forum. And then, issue you submitted to the Support page at 8:17 last evening, you reported the above, plus the fact you could not find a way to post anything to the forum.
Why it was necessary to report the same issue three times in as many minutes is beyond my comprehension. And then, within 10 minutes, you are submitting nearly all the same information to this topic. Since I see you have managed to find the appropriate links to click to both read and reply to posts, I'll disregard your warning about the forum not having many members. And, hopefully, with the above images supplied, you will once again be able to find the View New Content link.
Third - I offer my sincere apologies for not being present to answer your 'WHAT'S GOING ON' demand at 8:15 last evening. I apologize for not being here at 8:16 last evening. I apologize for not being here at 8:17 last evening. And I apologize for not being here at 8:27 last evening. How rude of me to actually have a life away from this site. I will try harder to shadow you, every moment you are on the forum, in order to offer you assisstance within 60 seconds of your requests.
And last, as for your questions as to what is going on? At the moment, not a whole lot is happening. I'm just trying to dig out this burr you jammed under my saddle, that's all.
If you need help, all you need do is ask for it. If you need to be rude about it, click on that link to log out and don't bother coming back. See, I'll not twist your arm to force you to visit a forum you cannot sort how to use. If you feel I need to be here to answer your questions within one minute of asking, your expectations are too high. I cannot meet those expectations, you are continually going to be disappointed by my inabilities and you need to click on that link to log out. Nobody is a hostage here. If you don't like it here, no one is forcing yo9u to stay. Take your leave and your problems are all over. See how easy that is?
Russ, if you'll link me to the posts where you are experiencing troubles, I'll take a look and see if I can tell what's happening.
