Corley
1) Does anyone know if a Turbo 350 torque converter can be used with an aluminum Powerglide?
2) Also, does anyone know if a Vega welded cooling fin converter can be used with a 67 impala aluminum PG? (In this case, I'd run it without the bottom converter cover to provide airflow.)
I need a PG converter, have a new turbo 350 converter, but might consider the Vega version if that would also take care of trans cooling. The Vega version has the advantage of helping raise stall speed. I understand that PGs tend to develope quite a bit of heat due to converter slippage from the gearing provided. This would be behind a 229 CI Chevy 90 degree V-6, so not a real powerhouse, and used in a 'T' bucket, so it's going to be a very light vehicle.
3) I also need a flex plate for this. Question: Will either the 153 or 168 tooth flex plate work with this combination?
4) Will a neutral balance V-8 flex plate work OK on the 229 V-6 (non - 400CI)?
Online research is quite confusing due to so many wrong answers, speculation, and uniformed responses, in some of the other forums. ("A buddy did so and so ...", "I THINK you can...", "I'm and expert and you definetly can hook a Buick dynaflo to a flatty Ford, it's a bolt up", etc.) You guys should know a lot about small block chevies, so give it a go. Any PowerGlide facts appreciated...
Corley
PS Why PG? I have a PG behind a stock 350 SBC in a '65 Jag Mark II, and it is a great combo, I like it better than when I had a turbo 350 in it. I think it works so well because this model Jag is not very heavy. It will pretty much leave tires at will up to about 30mph. Very drivable, so I'm thinking it might be a decent choice in the 'T' as well...
Corley
		 opinion, I would prefer the lower gear ratio of the TH350, even in a light-weight car.  And quite frankly, I think this is the situation here - it all boils down to your personal preference.
