Lowrollerchevy
yes the SS hairpin / 4link mounts are cheaper then the steel ones, this is because they are actually easier to cut from stainless
the hairpin mounts also come without the cutout for the tube axle, they just have a tic mark in the center of that edge, allowing you to mark / cut for your own axle diameter
the v8 column drops are self explanitory
the bottom item is the hairpin mount (frame side) that was drawn up w/ some input from a few members here. and it will come undrilled, and will need to be backed up in some way to prevent flex, either via a short piece of tubing the proper ID for the bolt, or an extra plate behind it
