Problems.....Solutions
Track-T
Problem 1.... Ugly E-brake cable housings....
Solution....... Cut housing off leaving mounting points to backing plate.
Problem 2..... Now cables flop around...
Solution........ Make a 1/4" flat bar across the frame and mount polished alum. tubes
redirect the cables.
Thanks, The main reason I post a lot of little stuff is give people ideas that might help..
Not everything will work for everyone, But something might
