radiator grill shell
ford4ever
Hi all,
I have never really paid attention to how the grill shells are attached to the frame. Do the headlight
brackets sit on top of the shell, then secure all together? does anyone have close up's of how everyone is doing them!
Thanks,
Mark
I incorporated the mounting tab for the grill shell on top of my head light mount which is on top of the tab that mounts the radiator. The two bolts that mount the radiator are separate from the shell. The angle that mounts the light has four bolts, two on the side of the frame rail and two through the mounting tab for the radiator. The grill shell mounting tab has two bolts that go directly into the frame. I don't have a real good picture but perhaps the attached one below might help.
My rad shell is mounted on tabs inside the frame rails and the headlight mounts are separate.
