Radiator question's
hickory
Hello All. I have a 29 Ford shroud, and I need to know what radiators will fit my shroud? Also how does a guy mount the shroud and the radiator, to the frame? Anyone have any pictures? The radiator will be cooling a 200 inline Ford 6. My T has a home made frame that originally had a big old 371V8 and a extra huge brass radiator with some big side mounts welded on to the frame. Any help would be greatly appreciated. Thanks, Jeff
any of the radiators for a T will fit in the A shell. ted is so right here. mount that puppy with rubber. if it is fashoned after a T unit, a tab off the in side of the frame rail will be enough. if your frame is too norrow for that, mount it to the top of the rail.
look at tfeverfreds build thread. he has all the info there with pics
