fluidfloyd
I'd post a pic or two detailing what you need to consider but I don't have time unfortunately!
Not all tri-five bearings were the same and there are certain ways to position the seals depending on the bearing type and year used.
Here you go...
Rear axle seal question - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
I did not realize the Chevy bearing had an external o-ring like the early Olds/Pontiacs. This was and still is the standard design used in most all drag racing cars today although most are based on the 3,150" OD Ford 9" bearing. Some early designs had a open face (no seal) on the differential side. The bearing was lubricated from oil spiraling down the axle shaft. With the bearing being double shielded there is no need for external lubrication. The o-ring design seals oil from working its way past the outer bearing case. Sometimes the housing can get egg shaped due to high wheel impacts, welding warpage either radially or out of square (perpendicular) to the differential. This is one of the reasons I don't like heavy welding on the axle tube without re-aligning or replacing the bearing housing. Hope this clears the air to some extent. Thanks for posting the Chevy bearing link. I learn something everyday.
George
