Rod Ends
rb61069
What type of rod ends are others running for suspension and steering? precision,chrome moly or aluminum
Which one looks best and which one performs best?
I am using the speedway locost steel. i pollish them and a clear coat and off we go. I wouldnt consider any aluminum rod ends
I am using the QA1 XMR series. Chrome moly with the Self Lubricating and Self Sealing Teflon and Kevlar Race. Expensive, but I do not want to mess with the safety of the suspension.
Ditto on the QA-1 XMR series. Gives you peace of mind as you're going 65 mph down the road. Also using the Speedway $30 ones.
I am installing the speedway steel rod ends on my tbucket I have the tapered cones and seals,and need to know the proper method and lubrication for these.
Also i recomend the safety washers on the outside so if you suffer a failure you wont need an ambulance ride.
