Seat Ideas
sschutze
I measured the rear seat in my 93 Camaro, it looks like it may be a good fit for a seat in the Bucket. The Camaro has 2 (bucket) bottom cushions and a solid back cushion. If I remember they are about 42" wide, which may fit in a bucket a little snugly, but I think it would fit.
I'm going to pull mine out of the car and set it in the bucket to confirm this.
The nice thing is there are usually 4 or 5 of these Camaros in the local Pick-A-Part at any time. I offered them $20 and they said if there is one in good condition I can have it.
I was thinking of the same thing please post back if it does fit and pics if possible. There's a boat load and camaro and firebirds at my area u-pull-its!
I pulled the rear seat out of the Camaro (sorry, no pictures), the seat back is narrow enough to fit in the T-Bucket body and would need some modification to secure it. It has to be positioned behind the bottom cushion so it doesn't stick up over the top of the body, and it isn't curved so it sits further forward than I would like reducing the limited leg room I already have. The bottom cushions have no metal support frame (just a stiff molded foam covered in fabric) and the because of the back cushion being positioned behind them, they stick out further than I would like (by more than 6 inches) so they would have to be shortened to be comfortable.
I'm sure someone might be able to make it work, but it seems like more work than it's worth in my opinion. I think I'll fab my own, that way I can get it to contour to the body better and be able to regain more leg room.
'87-'89 Ford Escort
rear seat Seat back width = 42"
Seat bottom width = 42"
Seat back thickness = 3.5" (seat back folds forward)
'90 Dodge Caravan,
middle seat? Seat back width = 44.5"
Seat bottom width = 44.5"
Seat back thickness = 4.5"
'80s Isuzu Trooper
Seat back width = 48"
Seat bottom width = 48"
'84 Ford Ranger
Seat back width = 49"
Seat bottom width = 49"
'84 Toyota van
middle seat Seat back width = 34"
Seat bottom width = 36"
Seat back thickness = 4.5" '91
Ford Festiva
Seat back width = 38"
Seat bottom width = 48" (odd shape is fitted to wheel wells)
'89 Ford Aerostar
middle seat Seat back width = 39"
Seat bottom width = 46" (odd shape)
'91 Chevy S10 pickup
bench seat Seat back width = 48"
Seat back width = 5.5"
Seat bottom width = 49.75"
Seat bottom thickness = 6"
The seat would bolt to a flat floor, with the frame the bottom cushon at highest point looks to be 9.5" high. Bottom cushon has two holes for seatbelts to pass through.
Wrangler stuff
(pretty small - maybe good for Model A)
Seat Back Width - 32.5"
Seat Back Height - 15.5" (from hinge)
Seat Back Thickness - 5"
Seat Bottom Width - 33.5"
Seat Bottom Thickness - 5" (at bolster)
Seat Bottom Depth - 15.5" (front to back)
Found one that mounts to the floor in a severely channeled 26-27 T
90's Isuzu Amigo back seat.
SEAT BACK 39"x21"x3"
SEAT BOTTOM 39"x20.5"x8" Seat folds forward and the "folded seat" folds forward again!
85-6 Dodge Colt Vista van
rear (3rd) seat. 38 inches wide-21 inches deep.
integral retractable belts (center) earlier ones don't have headrests thin cushions and backrests
This is from the other bucket site hope it helps.
My two bucket (one piece - none folding) seats are 37" wide, bolted together total width, perfect fit, I cut the high back head rest off, so they are pretty even with the back of the body, better to cut a bit more (lower) and also make the backs thinner, that will give even more leg room, super comfy... :)
What did you get the seats out of Ted?
I'm using a 1998 Camaro back seat in my Spirit bucket and (when flipped upside down) fits PERFECT.
