Seats
itsed2
Hay I read a while back of pinto seats and caravan seats, can any one give me the run down again.. sorry i was to write it all down and didnt and now I cant find it listed ,, If you can tell me what seats and if any mods had to be made .. I cant afford the aftermarket type at this time ,,( (I came down with something and been off a couple yrs) so Iv got to kinda do it a cheaper way for now thanks a lot and like always ,, if any thing is needed just ask these guys will know ..:jawdrop:
Here is a post Putz made to me, about a seat.
I just put a middle seat from a dodge caravan in my bucket great improvement.I had to cut the back corners off the frame bottom and took the frame out of the back and velcroed it to the body alot more comfy.
Is this what you where referring to?
'87-'89 Ford Escort
rear seat Seat back width = 42"
Seat bottom width = 42"
Seat back thickness = 3.5" (seat back folds forward)
'90 Dodge Caravan,
middle seat? Seat back width = 44.5"
Seat bottom width = 44.5"
Seat back thickness = 4.5"
'80s Isuzu Trooper
Seat back width = 48"
Seat bottom width = 48"
'84 Ford Ranger
Seat back width = 49"
Seat bottom width = 49"
'84 Toyota van
middle seat Seat back width = 34"
Seat bottom width = 36"
Seat back thickness = 4.5" '91
Ford Festiva
Seat back width = 38"
Seat bottom width = 48" (odd shape is fitted to wheel wells)
'89 Ford Aerostar
middle seat Seat back width = 39"
Seat bottom width = 46" (odd shape)
'91 Chevy S10 pickup
bench seat Seat back width = 48"
Seat back width = 5.5"
Seat bottom width = 49.75"
Seat bottom thickness = 6"
The seat would bolt to a flat floor, with the frame the bottom cushon at highest point looks to be 9.5" high. Bottom cushon has two holes for seatbelts to pass through.
Wrangler stuff
(pretty small - maybe good for Model A)
Seat Back Width - 32.5"
Seat Back Height - 15.5" (from hinge)
Seat Back Thickness - 5"
Seat Bottom Width - 33.5"
Seat Bottom Thickness - 5" (at bolster)
Seat Bottom Depth - 15.5" (front to back)
Found one that mounts to the floor in a severely channeled 26-27 T
90's Isuzu Amigo back seat.
SEAT BACK 39"x21"x3"
SEAT BOTTOM 39"x20.5"x8" Seat folds forward and the "folded seat" folds forward again!
85-6 Dodge Colt Vista van
rear (3rd) seat. 38 inches wide-21 inches deep.
integral retractable belts (center) earlier ones don't have headrests thin cushions and backrests
again like always ,, you all have come threw with the right replys , thanks you all are a lot of help
Hay I read a while back of pinto seats and caravan seats, can any one give me the run down again.. sorry i was to write it all down and didnt and now I cant find it listed ,, If you can tell me what seats and if any mods had to be made .. I cant afford the aftermarket type at this time ,,( (I came down with something and been off a couple yrs) so Iv got to kinda do it a cheaper way for now thanks a lot and like always ,, if any thing is needed just ask these guys will know ..:wacky:
i used the foam only from a dodge mini van (center) and made the fame from wood like a boat here's a couple of pics hope this helps. i also cut out out the seating area and wove in a webbing out of parachute cord
