Mr. Fixit
As I am designing my scratch built steering column, I wanted to include self cancelling turn signals and horn button. As a motorcycle owner/enthusiast and builder, I knew of a product that would do the job and wanted to share it with you all.
Here is the link to Signal Dynamics. They have a lot of great products that we can all use in our builds, but specifically this link is for the lighting control for self cancelling signals. In order for this to work, each side (left and right) has to have a momentary NC (normally closed) switch as would typically be used on each side of a motorcycle handle bar as an example. I will be incorporating this type of set up in my column which will be actuated by a standard type turn signal lever. As I get further along with this, I will post photos of the inner workings.
http://www.signaldynamics.com/lighting_control.htm
