setting toe in
adey
i am trying to work out how to set the toe in on my front and rear suspension. The front and back shouuld have 3/32 toe in.
do i halve this for both sides?
and how is the best waty to set the rear up as this has to have a toe in?
any help would be most welcome
Try a search. There's several good threads on this subject. I don't think the rearend is toe'd in or out. I just make sure it's in there straight.
3/32" sounds OK, that would be a total measurement, so yes half that for each side. Do you have a Jag independent or similar? as I'm pretty sure they need a little toe in like the front to track straight, as they develop a little toe out under accelleration with movement in any of the rubber bushings.
