thebearded1
This winter I'm looking to extend the rear of my frame by about 1 foot to allow for a push bar/bumper and maybe the rear legs of a bolt in roll bar (not for street use). The frame is 1.5"x3" 1/8" thick tubing and I was going to use a smaller sized tube inside as a slug to plug weld on the original frame and frame extension. The problem is I can't find any steel tubing that will fit close inside. Current inside diameter of the tube is roughly 1.25"x2.75". I can find 1"x2.5" tubing should I do that and add in some 1/8" flat stock to take up the gap? I could drill the original frame and the flat stock so that both could be plug welded to the slug inside.
Any other ideas for this?
