side step
We make these in a kit for both left and right side. they can be bolted on or welded.
I picked up a set of steps from a horse drawn carriage.that go out then up. probably from a carriage that had double steps. Most have about a 8-12 inch drop. just right for a T speedster.
Ron.....now THAT is just plumb slick!!!!!!:shrug:
When I order my brackets from ya........I'm gonna have to get a pr of those!!!!!:face:
Where on the frame do they attach?
mine are actually welded to my radius arms as you can seen easier for us old guys to get out. Theses are old total performance steps.
The first set was built off of a Spirit car that we had here in the shop. So we were able to make them bolt onto their rear radius rod bracket that is welded to the frame. Unbolt the radius rod slip a plate in between the rod and the frame bracket and bolt it back up. You may have to have a longer bolt. Then we drilled 2 smaller 3/8 holes thru the frame bracket to keep the step from turning.
That is Fast Eddies car pictured
