"The Bat" out of hell
For a low$ speedO that is rite on the rite mph for your rod;
A trick I used way back,and still do when building my own rods,is to get 2 for 1 out of dash holes and save some $ too,I like having a tach and first rod I ever built only had tach,oil,temp and volts,nothing more,after some time driving around ,I made a nice alum 1in. wide plate "ring like a real big washer" to go just behind the tach and around out side of tach,and nicely marked MPH on it,at the RPM in high gear that was a match up to a frenids car that was stock and had a good speedO. The need part beside saving $ is you can mark some real high MPH on the RPM part your motor hopefully will never run at
How you make your MPH ring is up to you,but even just number and letter stamps can work nice and polish it up shiny after.
