akitagandy
What is the purpose for running a second solenoid on a Chevy?
Could someone show me the correct way to wire this setup?
Bruce, I wire mine totally different than that setup.. That is way too much cable and work for me... I just use it as a short cut for the starter button... just 2 #10 wires to a HDuty starter button (one from Battery, then back to solenoid) will do the same thing, stop all the hard cranking problems without having to buy all that heavy battery cable.. Hard cranking also happens in the Morning before anything even gets hot or even warm on engines with HP.. this will cure that forever... Try it, you will like it... to test, I tell everyone to leave their old stock wiring intact, try starting with the key, then the button, all the difference in the World... Happy starting :thumb:
Well I reckon when you bolt it down it is grounded for sure, and you only need to use #16 wire (or smaller) to the starter (ground type) button, bout as simple as it comes...and I only use #10 wire at both side posts where they usually use a full battery cable...Does the Ford solenoid have to be grounded?
My ford solenoids had to be grounded. i use 2 of them one for the starter so the cable going to the starter isnt hot all the time and the other is my ACC that controls the 12 volt to the fuse panel,fuel pump,headlts,and so on . So the key turns the ACC solenoid on and supplies all power to everything rotating the key to the start position energizes solenoid 2 and starts the car. so when i turn the key off everything is really OFF. Remember that the Ford starter solenoid is NOT rated for continious duty ONLY for starting only. If you use a traditional ford solenoid for anything other than the starter it WILL BURN UP!!! I repeat IT WILL BURN UP!!!! I went to a winch supply in okla city and picked up a continuious duty solenoid and it looks just like the ford starter type but it isnt.
Who knows?? maybe the solenoid I have works or is different? one small post is a 12 volt going out,(I may not have that post? I will have to go check that out) the other is to a grounding type start button...All ford solenoids need grounding the base is metal and when attached to the firewall or frame provide the ground for the solenoid coil. The posts on the solenoid are the battery in and out . the small front posts are the ingition coil 12 volt out and the solenoid coil 12 volt in to start. The only Ford type that doesnt need grounding is the forklift style with 4 large posts and 1 small front post.
just my opinion
