one finger john
Gentlemen, Is a T that handles an oxymoron? I have seen different set ups that positioned the front axle so that there is no lateral movement while cornering. One appeared to be a tongue & groove arrangement that fitted between the axle and and the spring mount and it looked to be a potential binding point for axle movement. The other was a three point setup that had the anchor points to either side of the frame and one point on the axle. Is the last effective? And relatively easy to make and tune? I will be staring with either a used frame and will adapt a front end system or maybe a new frame with the adaption already done. I really like Donsrod`s frame layout and would like to copy the lines of that if possible. If there frame plans or pictures I would really like to see them. If anyone has any comments or observations please jump in. And I mean anyone.
Thanks, John
Thanks, John
