I'm starting a project that is probably going to be a little more hot-roddy, but the basics are the same, so please keep the pics and comments coming. Next T is going to be steel.
Jeff
Jeff, if you are doing a pre-'26 body, you'll be surprised at the compromises that have been done to make the glass bodies.
That would be cool youngster with your frame "A" front axle, banjo rearend , flathead 3 speed all paint no chrome on the motor,stopsign floor boards,minimal interior,a cool logo on the side and just seal the body in primer or something flat ,oval fuel tank with the round bracket mount tail lights.wire wheels, and low as she will go.
I was having trouble getting the recurve shape in the cowl patches so I built the body sub frame. I was going to make it out of wood like it was originally. The problem with that is I wanted something more ridgid. The body has enough stress cracks in it already. I had some "C" and "Z" channel bent and put this together last week.
Tried the side pannels and it's easy to see they need some more work to get them to fit. The frame mounting brackets will be welded to this. Qestion now is, do I do the rest of the body wood in wood or metal?
