When I bought my T, I liked that the steering wheel came up out of the floor, leaving lots of room in the front for the motor. It had a reverse Corvair and drag link that I wanted to reuse as well.
First problem came when I mounted the steering and sat behind the wheel during mockup.
I am a tall guy, and my left knee got stuck between the steering wheel and the side of the cab.
So I welded a 4 inch extension into the middle of the steering shaft, then found a 3/4" race and mounted it about 4 inches above the floor for stability.
Problem solved... but...
On the first test drive I realized how wobbly the steering column felt, just shy of the skinny end of a fishing pole sometimes.
I can deal with it, but I don't think anyone else would feel safe.
A tape measure reads 16 inches from the shaft to the firewall parallel to just under the extra instrument cluster.
There isn't much room for my size 12's as it is... and I'm afraid if I do a wedge shape brace it might make it even more of a pain to wrap myself into the driver's seat.
Any thought or suggestions would be much appreciated.
![IMG_3799.JPG IMG_3799.JPG](https://tbucketeer.com/data/attachments/15/15617-a3a454305ca7d90cdbcc518e39f9bcb8.jpg)
![IMG_3797.JPG IMG_3797.JPG](https://tbucketeer.com/data/attachments/15/15616-6c33121c8386966a8d6a69aefef9359c.jpg)
