Francis Blake
Speedway has a similar setup on page60 of cat#260.
LKE said:Ok... I have played with racks on drop axle cars several times. And here is what I have learned. First, they do work, and work fine. The first T I built, had a rack mounted to the chassis, and it did not have any bump steer. Everyone said it wouldn't work, couldn't work... Well after completing it, and seeing how well it did work, I went looking for answers. Answers as to how I got it right, when everyone else got it so wrong. And the guy I turned to was a friend of a friend, that happened to be an engineer at visteon (visteon is, or at least was at the time, a tier one oem supplier). But not just any ol' engineer. An engineer in the steering department. He had 7 us patents on steering gear design and had written sae tech papers. He was a for real steering expert. So I sent him photos and asked lots of questions, and what I got back was interesting... at least to me. The first thing he shot down was the theory that the axle moves straight up and down, and the rack ends move in an arc, causing toe change and bump steer. While that is true, in reality, you are not going to have both front wheels hit the same bump, at the same time, to make the axle go straight up. In the real world, you are more likely to have one wheel hit a bump, or drop in a pot hole. In which case, the axle moves up and down in an arc, because it pivots on the spring that is center mounted. Where people are having problems with the frame mounted rack, and the transverse spring, is the spring shackles. As the rack pulls on one side, and pushes on the other, the shackles and the spring deflect, shifting the whole front axle. A simple panhard bar is the answer there. I never had this problem, as the car I built had a torsion bar front end. The 3/8" thick chrome moly arms held the axle in place. In wasn't until later that I discovered this.
The next thing I found interesting, is that there is no set number of toe change, that will cause bumpsteer. You can't say " if you get over 3/32 of toe change it will bumpsteer". Right from someone that designs the parts in the cars we drive... He said they have no firm numbers. It depends on many variables. With all the sophisticated computers, and programing, and all the education, blah, blah.... At the end, they make thier best guess, and build it, and drive it. I was also told that rack placement can be very critical. Sometimes moving the rack as little as 1/8" can make a big difference. This is where I think the swap isn't for everyone. If you do not want to take the time to make sure it is 100% the best it can be, move on to something simpler.
The next time I did a rack on a straight axle, I mounted it to the axle. This I did NOT like. This was on a Model A with air ride. Because of the large amount of suspension movement, mounting the rack on the frame would not work. So on the axle it went. The thing I didn't like about it was that The steering shaft has to move as the axle goes up and down. Everyone I spoke with suggested a slip joint. I did not like that because it introduced play. It can't be set up tight, or it won't slide freely. And I was afraid if it didn't slide freely, that it would bind the steering or possibly causing bump steer. The other option was to put in a u-joint and have it pivot to match the suspension. This might be OK on a car with headers out side the frame, like a T, but on a model a with a full hood, not so easy to do. I can't find a picture of this set up. I found the air ride pics, but none showing the rack.
And the last one... I didn't do much on this, outside of maching a few parts and a little tig welding. My father did all the fitting etc on this (it's his latest car). It is a rack mounted thru the frame, and only one side is used to push the drag link. Works pretty good. He's got one cruise season on it, and is happy.
You may be wondering why all the work with the racks ? Well 2 reasons, one... they have better leverage ratio's than the typically used boxes. Which means easy steering. All the ones I've done have steered very nice. As close to power steering as you will get without the pump and all the hoses. And two, they are cheap, light, and compact. We have been using geo metro racks. They are $40 at my local pick n pull.
Is it for everyone, NO. If you are not willing to put in the time to make sure it is installed properly, and willing to do some testing, I would walk away. And it is not a simple install, machining, fabricating, and welding (sometimes on delicate parts) are all part of the deal. But, If you are willing to do the work, and it can be some work. You can end up with a nice system. My father wouldn't own a T without one. Me? My car has a vega box :razz:
RPM said:Unisteer would be the way to go with a rack and pinion.
Sets up like a cross steer on Vega box mounts
Unisteer Performance Products Cross Steer Rack and Pinion : JC Whitney: Auto Parts & Accessories
EX JUNK said:LKE does not post that often but when he does, he speaks volumes. His posts are always VERY informative and to the point. His knowledge comes from designing and building suspensions and vehicles for many years. We are indeed, very fortunate to have him participating on this board.
