deckofficer
Banned
Well,
Santa (the UPS guy) probably isn't too fond of 110 lb boxes, but the TKO 600 5 speed arrived today. I found out that my old Muncie was an M21, not the M20 wide ratio I thought it was. First gear in the M21 is 2.20 to 1, while first gear on the new trans is 2.87. Should make quite a differance getting off the line. There was 3 reasons for doing this swap now, the new 383 stroker exceeds the torque rating of the Muncie by 200 lb/ft, 2nd, I've always wanted an overdrive gear for the T, and 3rd, my hydralic throw out bearing crapped out. The od ratio is 0.64 which will make highway cruising quite pleasant and the torque rating of 600 lb/ft should carry me through my final engine upgrade. It never ceases to amaze me the cost of the little items, like $50.00 just for the O-ring kit (10 O-rings) for the hydralic clutch, and get this, $50.00 for a plain white shifter ball with the correct shift pattern engraved on the top. For you gear heads.....
gear Muncie M20 TKO 600
1st 2.20 2.87
2nd 1.64 1.89
3rd 1.28 1.28 rear gears 3.54 rear tires 31" diameter
4th 1.00 1.00
5th NA 0.64
So, at 65 MPH, I'll be at 1600 RPMs. As some of you might have read, my hope was to go with the 6 speed and a 0.50 overdrive so that I could "idle" down the highway at 65 MPH at 1250 RPMs. My driveshaft is 14.5" and has a yoke to shaft angle of 4.5 degrees. The 6 sped was 5.84" longer than the Muncie while the 5 speed is 2.19" longer. I hope to bury more splines on the yoke to trans output shaft so that I only need to shorten the driveshaft by some amount less than 2".
Pictures (from an outside site) will be posted on follow ups of the progress.
Merry Christmas and a Happy New Year to all,
Bob
1st 2.20 2.87
2nd 1.64 1.89
4th 1.00 1.00
5th NA 0.64
Bob
