I THOUGHT I had worked out a weak link in my steering that had caused a nasty death wobble when hitting a pothole (which my town is riddled with) by fixing a bad drag link end that was causing a little play in the steering. After a couple of days of smooth sailing I had the issue again today.
There is no play in any of the steering components up front, king pins are good, etc... I do however have some play in the steering box. I'm not sure if that can be adjusted out, or needs to be replaced, or if I'm even on the right track.
Any idea if that could be the culprit, or do I need to focus on the front end components?
Thanks in advance!
Thanks in advance!
