Toe in, Toe out
Duke
I have heard that on Bias Ply tires you should run 1/8" of toe in, but on Radial tires you should run 1/8" toe out. Any words of wisdom out there on this subject ? :confused:
That's the information I've read in the tech section of the NTBA site and that is specs listed in my Total Perfomance constructors manual.
Bias Ply tires: 1/8" toe in.
Radial tires: not more than 1/8" toe out.
As to why that is, I can't answer that.
I do know that neutral or 0 toe prevents front end vibration but the front end will tend to wander due to imperfections in the road surface.
Hope this helps.
JC
