It will stop with moderate pressure but the engine sputters and dies.What's the idle speed at full stop with transmission in gear? Do you have to stand on the brakes, or will it hold with light-to-moderate pressure?
Guess I should have left out the cold part, I let it warm up before I drive it. Don't know the cam specs but it goes "Bumpity, bumpity, bumpity............................................bumpity, bumpity, bumpity.........................................etc. Not as much as Island Girls motor but does idle like a big cam.So it's OK when it's cold ? If it is, then it can't be the torque converter.
What are the camshaft specs ?
What does it idle at while in park ?
Previous owner just had a blower shop install and adjust new blower carbs right before I got it. I have the receipt.I would look first at the float bowl level.
Nope, another state away. I just have you guys.Can you take it back to them for adjustment?
Ok. as soon as I get the new exhaust gaskets in and the new baffles put it, I will give it a try. And take note of the idle speed as Indycars suggested.Try raising the idle just a bit and see if it makes a difference.
Did they drive it?Previous owner just had a blower shop install and adjust new blower carbs right before I got it. I have the receipt.
I was told that the blower shop people did drive it and bless it after the carb install.Did they drive it?
Could there be a big difference in elevation between the blower shop and your location ?I was told that the blower shop people did drive it and bless it after the carb install.
Exactly, or different temp/humidity due to season, etc... anything else, such as timing, been changed? How are the plugs? Lots of possibilities.Could there be a big difference in elevation between the blower shop and your location ?
Idle speed bounces between 500 and zero at full stop with tranny in park. 1000 feet or less altitude change. Seems raising the idle is first on the list. Baffles are in and made it the perfect mix between deafening and hot rod sound. I can actually hear the blower now. Exhaust gaskets are in and no more leaks there.What's the idle speed at full stop with transmission in gear? Do you have to stand on the brakes, or will it hold with light-to-moderate pressure?
That's too low, even for a stock motor. I suspect your idle should be around 750-900 rpm whenIdle speed bounces between 500 and zero at full stop with tranny in park.
Indy is correct about idle too low. Also, if you added baffles since it was tuned, changes likely occurred in the a/f mixture. After trying the idle speed increase, it may need a slight carb retune if problems persist. It’s hard to diagnose by description.Idle speed bounces between 500 and zero at full stop with tranny in park. 1000 feet or less altitude change. Seems raising the idle is first on the list. Baffles are in and made it the perfect mix between deafening and hot rod sound. I can actually hear the blower now. Exhaust gaskets are in and no more leaks there.
