akitagandy
Has anyone ever heard of or use Continental Torque Converter Torque Converters , CTConverters.com Continental Torque Converters
and what do you think about a 3500 stall
Lee_in_KC said:Some observations from my personal experience...
I have a TCI converter that TCI rates as 3,000-3,400. They give a range because they say there are many variables that affect actual stall speed, the main ones being the weight of the car (resistance to acceleration) and engine torque in the stall range. A lighter car will have less resistance to acceleration and so the effective stall will be toward the lower end of the range. A higher torque motor will move the stall to the higher end of the range.
The highest RPM I have ever seen on mine during power-braking is about 2800... above that I can't hold it (torque overcomes the rear brakes). Stomping on the loud pedal while idling along at about 25 mph will give me a "flash" stall of about 3,000 before the tires break loose.
I have a transmission temperature gauge so I am able to see what is happening under various driving conditions. I also have a tube-and-fin cooler. Under normal cruise in typical summer weather the tranny temp stabilizes around 180. In city driving (stop and go) I have seen the tranny temp get up to about 210. I assume this due to the slippage in the converter as city RPMs seldom get above about 2500, plus the frequent idling at stop-lights in gear and accelerating away from stops.
Even with what most would consider a fairly high stall, I still have to keep a noticeable amount of pressure on the brake at stops (I idle at about 900 due to the blower and a lumpy cam).
HAceT said::hijacked: Hey Don you just hit a 1000 post. :toast:
What did I win?????? :toast:I'll take door number 2. :hijacked:
akitagandy said:Has anyone ever heard of or use Continental Torque Converter Torque Converters , CTConverters.com Continental Torque Converters
