jimbo01
I have to agree on the tech article idea. The only thing I would ask for is to have it broke down to where everyone could make use of the information. This may be easier said then done. About the only thing I have understood with all my reading so far is, a stock set up will run cooler but my passenger may be required to get out and push start me if I get caught up at a light, and if I go to a larger then stock converter the power will be put to the ground but at a price. The fluid may run so hot that I may be rebuilding transmissions every season or replacing the tranny fluid as often as I can afford to try and minimize damage if I can't get the heat down. I'm a little skeptical on the heat sinks ability to cool the fluid.
I'm also inclined to think that from all the experience and number of years and with all the T's that have been built, there would have to be someone that could almost pin point what size converter that would work the best. I understand that each cars set up is going to be different and affect the final results. But then again, there are only so many combinations that are being used.
So if my stock TC stall speed is 1400-1600 rpms, and from what I've read I should be using something that's 200-500 over stock. Then I look over everything that has been written here on the site or available on the internet and it always leads me to blow everything I've read way out of proportion or take me right back into that same brick wall. I really hope that I'm not over complicating this. Once again I'm just looking ahead at a future project. I can start to think this out now and make some plans or do it at the last moment and ask the kid behind the parts counter that would be more then willing to help me with what he had learned in high school shop class and help empty my wallet along the way only to find out that I can't return the part he sold me.
