Towing question
QuadBart
I did a search for "towing" and didnt find what I was looking for so I'll just ask.........
Has any one towed a "T" using a "Tow Bar" ???
I can make a bracket to clear the steering linkage for the tow bar, and attach it to the frame.
Ive read on RV sites you need to leave the steering unlocked.
Thats not a problem....... it doesn't lock anyway. LOL
My concern is, how well do they track behind a tow vehicle?
I have a Chevy Colorado that Ive used to pull an 18 ft trailer loaded with 4 quads , gear , and various tools.
Steve
DEFINITELY disconnect the drive shaft. You can do that at the differential u-joint and tie the shaft up out of the way. If you remove the shaft completely, be sure to have a plug in the tail shaft of the transmission in place of the drive shaft to avoid loosing fluid.
