As I noted in my new member introduction, I have gone through most of the archives - all 50 pages of the suspension forum archives - and boy have I learned a lot! I actually found one post by 72442conv that addresses the issue that I have with using some TP/Speedway wheels that I bought used. 72442conv had said that he would check back in after going to the machine shop, but I could not find his follow-up post. I have tried to start a conversation with him with no response, and the information on his profile says he hasn't been seen since 2012. Soooo, here goes - my bucket has Econoline spindles with drums. All these TP/speedway wheels are for pre 1949 ford spindles. 72442conv found that there are bearings that can be used to compensate for the difference in the spindle and hub diameters, but there is a small matter of a 1.2 inch length difference - Econoline spindles are shorter. 72442conv said he was told that his wheels could be machined such that the bearing race could be moved further into the wheel hub. He was actually using Radir 12 spoke wheels, but same issue. These wire wheels seem to have plenty of meat in the hub, if that is even a realistic possibility. Changing spindles would require switching out my chrome front end - too costly. I would really like to use wheels! Anyone have experience or knowledge about this situation? Thanks.
Ed
Ed
