Humidi-T
went into it this weekend. I found the right side accel squirter was clogged. I cleaned it out and I'm getting even squirt now. Went through the 4 corners idle adjustements. I set the carb on high idle, and opened each corner up till it sputtered, then closed it back completely then back off 3/4 turn. Then lowered the idle back down. Took it for a test drive and found it very rich at idle.
Turned the screws down to 1/2 turn and reset the idle. I got the cam lope back at hot idle, and it is much leaner, though still rich. Previous setting, the cam lope would go away after it warmed up.
Drove it today, and turned the idles in just a hair more, and adjusted the idle again. Getting close to 1/4 turn out on the idle adjustments. It is leaning out, and still running good. Cam lope is more radical than I previosly thought. I LIKE it!
Now that I am paying attention to the carb, the vacuum secondaries are coming in too late. I'll need to fix that before very long. it is nice to be able to have someone sit in the car and watch the carb linkages work.
Also have a small vac leak at the forward throttle shaft. not bad... yet.
