Valve cover baffles . . .
On my sbf I made a breather that mounts to the fuel pump mount since I have an electric pump. You can buy the breathers from K&N.
I just used a 3/4" 90* piece of conduit and cut it to my liking, then welded it to an old FP block off plate.
Cool idea! I like outside of the lines ideas.
Lets see if I can post a pic of what I am planning on doing...
I have some bolt on Offy breathers, ground the contour of the valve cover corner, made a jig to hold it while it gets welded. I have to find a welder to do it. Next would be to figure out what size hole(s) to drill in it, I'm using a PCV valve on the oil filler neck mounted on the intake man.
Do those offy breathers have some type of filter media in them or are you gonna just suck all the dirt through your engine ?
Two layers of sponge sandwiched by 3 s/s mesh screens. The sponges are the black things in the center along with the screens. (click on the thumb nail)
It's a stock set-up for 67-68 I think, just had to make sure to get the right PCV.
