Its not really anyone's front end. Instead of the more traditional "buggy spring" and friction shock set up, my '27 has a pair of Carrera coil-overs. To run coiloverfs on the fron, you need some stiff mounts that have been triangulated or gusseted. My shock mounts (and the ones on my dad's 27) are made from surplus 3/8" bent plate I was give at the end of the building project I was working on. naturally, there are clearance issues as well as aesthetic issues with this set up. The headlights cover much of the coilovers. I like this set up over a traditional set up as there is a bit more adjustability built in.
