Windshield
Track-T
Got my windshield from the shop....looking more like a car. Cost all of $70.00
I'm going to take a WAG and go out on limb and say Photo?
Gezzzzz guys, did a quick post before I went to see my 16th. grandkid that was born thur.
Here are your pics. And yes, the windshield posts are taller then the glass, that is because the top header fits over them.
Cool !
Is the frame aluminum, are you planning on polishing it or painting it?
The posts are 1/2" alum. with 3/16" alum. on each side, they are just painted. I didn't feel like
going through the hassle of polishing.
The glass will have a rubber U channel between the glass and the cowl.
The small brackets on the posts are the latches for the top.
Lookin' good!
That's a really nice looking frame. Wait... did you say "latches for the top"? I'd like to see more details on that area, especially the hardware that's part of the top. I'm in the process right now of designing latches for my bucket windshield that will hopefully let me take the top up and down.
Jack
Took some steel tubing and cut a notch at one end,bent a steel rod and fit it to the tube. wrapped the tube with .090 alum. installed a washer and pin to keep it inside the tube.
ended up with a slide pin setup that mounts to the header into a bracket on the posts.
