Looks like your uph, is holding you forward too much, that is whats making it too short for your legs, if you want to make it a track T, you will probably have to extend the cowl & firewall forward 6 inches at least, some have gone a full 10 inches, the long cowl looks good anyway, and then you can do a thicker (1/2") firewall that is just the small amount smaller than the body, for the hood to rest on, easy lip... Plus you will also want to change the steering to get the wheel in a more normal position, that also gives you more inside room.. COMFORT !! YES... :welcome:
