Loric Labourot
Last Friday I changed the disc brake pads on my performance machine front brake calipers and tomorrow I going to I install a new trans mount biscut on the C4.
This Monday I am taking the C cab to front end alignment shop to check the caster angle on the four bar front suspension and the toe in. I have four brand new mickey thompson sportsman radials that I recently put on the car and I want to get the best set up on the front end.
Last year when I bought the car I replaced the old Koni coil over rear end set up with a pair of QA1 coil over shocks. The new shocks made a big difference in the ride. The car weighs 1756 lbs with 624 lbs on the front and 1132 lbs on the rear and springs and pressure adjustments made a huge differance in the ride.
