? about Model A springs in a 1200 # T
I'm running Model A springs front and rear with split bones.Front end is all A.I'm running ford 2.3 and auto with a Ford Maveric 8 inch.With all the spring treatments out there id like you opinion on what I should due to the springs to give a bit better ride.i have removed every other leaf starting from the main radiused the leaf tips to slide better.What do you think is the best thing to do between leaves This car is being built to drive a lot. Teflon/Plastic inserts,Buttons,Lubriplate and wrap what have you done,What do you suggest ? the car is a 27 Roadster pick up.
