Mr T Bucket
What size master cylinder bores would you go with if:
You're building what might turn out to be a really bitchin' T bucket, or, at least it is in your mind. 18" wire wheels up front with Airheart 175 discs and because you would really like to stop quickly you want discs in the back as well as integrated parking brakes, and the fact it'll look really cool with all the fancy hardware out in the open back there and besides, you would want to fully use the 29/18.5 Prostreet Radial rolling stock . Due to space limitations and the fact that it might be difficult to find an OEM master cylinder that would work reasonably well with that setup AND having to add the somewhat unsightly adjustable proportioning valve just won't do, you're planning on running a dual remote mounted master cylinder setup, similar or pretty closely related to Gerry UK's ride complete with bias/balance bar and whatnot.
The Airheart 175's have a 1.75 inch piston. The '94-'04 Cobra rear calipers have a 38mm, or 1.5 inch piston. If your choices for master cylinder bore diameters were .75, .875 or 1", which would you use and for front or back. I'm thinking for the front, use a 7/8 (.875) and a 3/4 (.75) for the rear.
Estimated/anticipated pedal ratio right around 6:1.
