Here is one that I did way back when, that was for a car where the owner had some very distinct ideas about how he wanted the wheels to set in the fenders. It has been so long ago that I can't remember whether it was shortened or lengthened...it seems like it was longer as it was an original E-type Jag. Anyway, I re-tubed the lower control arm and kept the position of the lower shock mounts in the same proportions as far as the leverage on the shocks. The original half shaft was the forged type and it was replaced with the fabricated style...2 yokes and a tube.
Youngster is right, you can do some juggling with wheel sizes and offsets. Lee is also correct in that the lower portion of the hub carrier can be a problem unless you go to some pretty large diameter wheels.
