Anymore thoughts or questions about a Jag rear?
Ron, I took all the Important info on the other thread and put it in your new thread. As Gerry put it to much good info to lose.
Further to George's post... the eight bolts shown in the pic go into threaded holes in the brackets that are already there. The plate replaces the bottom portion of the stock cage that holds the rear-end in an OEM set-up, and those holes are where the cage bolted to the bottom of the diff. Very important piece of reinforcement, in my humble opinion.
That's why mine are safety-wired. So are the top cone bolts.The bolts that go into the diff casting from the bottom pivots are KNOWN for loosening off. Even if you loctite them... Its where all the stress is concentrated.
Gerry
Actually Gerry, I believe the stock Jags are safety-wired. At least mine was. I bought my '77 XJ6 rear-end still in the stock cage, and both the top bolts and the bracket bolts were safety-wired. That's where I got the idea. I ordered stock replacement cone bolts from an on-line Jag parts house and they were already drilled for safety-wire.Jags dont use safety wire. Gerry
Lee
I stand corrected. I know the outer bearing flanges on the diff were always drilled for safety wire, as mine are now. But I cant ever remember the cone and carrier bolts being that way. But I use the OLD S type (60s) rear ends so maybe thats the difference. Either way i still say go with the safety wire or come up with a grub screw alternative to neaten thing up
G
Gerry, your brackets look to be custom fabbed. Mine don't look anything like that. They appear to be forgings with one large boss at each end where the swivel shaft passes through. You can kind of see them in this page from a how-to article I found back when I was working on mine. You can also see the safety wire in place.
One other thing that I don't believe has been mentioned in this thread and generally gets overlooked is the plate for the bottom of the center section. This ties the cast brackets that the lower control arms attach to so as to reduce the possible breakage due to the leverage of the arms. The cast brackets have two attaching bolts for mounting to the center section that are closer together.
heres a couple of pics taken at a show last year. Couple of British Ts using Jag IRS. Cool or what
gerry
