Gerry
Just an update on the new bits I have sorted out on the T this weekend
First up is the battery strap. Pics will explain.
Second is a tensioning pulley for the water pump belt. As I have NO ancillaries to run on the engine, just the water pump; a simple belt from crank to pump is all I need. Still as we all know these belts stretch and need to be tensioned every now and again. So task for the day is to make a tensioner for the belt. Started witha bit of 2"X1/4" flat. shaped and tried, a few times, then hey presto a bracket. Turned up the shaft which will run a needle bearing and small pulley. Plug welded the shaft to the bracket. Now just need to turn up the pulley for the needle bearing and we should be good to go.
By the way the white bar you see in the background (pic 2) is a body strap. I started with a couple of bolts thro the body to the chassis and then thought why not join them together and make a single strap mount. I will be glassing this in to the body soon. Its all about body/chassis/ seat belt mounts but more on this in the future
Gerry
Gerry
