I'd look into getting some tearoffs if your going to use lexan. The it helps protect the windshield and can be easily removed & replaced as needed. I used to use them on the faceshield on my full face motorcycle helmet. Came in real hand in the spring when the bugs were rampant.I haven't driven it yet, but I expect little if any bending at speed. I can't bend the channel piece by hand. Lexan is great. I got mine on eBay. There are several sellers who will cut it to your exact dimensions. Mine was only $60, I doubt I could get glass for that. It was available in clear or 5% smoke, and I did the smoke. It's very subtle. Lexan weights a fraction of glass, won't shatter, and cleans easily. And the NASCAR guys use it, so the strength is obvious. I'll update when I get back on the road in a month or so.
Yes, good catch, mine has the MR10 coating. Highly recommended.I knew you had not driven the car, but thought you might have a good idea how much the top brace helped. Does yours have a coating to reduce scratching or are you using plain jane Lexan?
Thanks!!!
