Welcome to Our Community
Sign Up
Dismiss Notice
Body snatched
Discussion in 'Bodies' started by Pushrod, Jul 30, 2018.
  1. Gerry
    Gerry
    Expand Collapse
    Dec 31, 2009
    2,644
    600
    Gender:
    Male
    So how many times will you need to remove the tank once it's done and dusted. Has the same set up on an early T of mine and never needed to take the tank off.
    12" extension, ratchet and its as easy and hell.
  2. Pushrod
    Pushrod
    Expand Collapse
    Feb 20, 2018
    266
    151
    Gender:
    Male
    Occupation:
    retired
    I finally found a tank, it's an old Nevins water tank. I cut the filler neck down and will TIG a quarter turn bung on it. I gave it a quick cleaning with toothpaste (works well) for now, but will eventually see how it polishes up. It's 12"x27" and holds 12 gallons.....that should get me to the end of my driveway. :thumbsup: IMG_1913.jpg
    Driver50x and lincolnuT like this.
  3. Gerry
    Gerry
    Expand Collapse
    Dec 31, 2009
    2,644
    600
    Gender:
    Male
    Just a suggestion.
    If you are going to weld a bung in, you may as well put a return pipe and breather pipe in at the same time, just in case.
    This is is the inside middle section of mine. I ran the breather right up into the neck and put a return pipe as far away from the fuel pick up as possible. I also baffled the middle section, but you don't have that options.
    G
  4. Neshkoro
    Neshkoro
    Expand Collapse
    Jun 29, 2009
    1,487
    745
    Gender:
    Male
    Occupation:
    Retired
    Pushrod, I like the tank. Is it made from aluminum?
    Gerry, I like your tank, too. It's nice you have the float in there. Currently. I have a stick to check fuel level. There is a float in my tank. It's just not connected to the fuel gauge yet. Maybe next year.
  5. Pushrod
    Pushrod
    Expand Collapse
    Feb 20, 2018
    266
    151
    Gender:
    Male
    Occupation:
    retired
    It's aluminum.
  6. Pushrod
    Pushrod
    Expand Collapse
    Feb 20, 2018
    266
    151
    Gender:
    Male
    Occupation:
    retired
    I'm going to use a vented cap, with a fuel line from the tank bottom and no sending unit.....is this a bad idea?
  7. 2old2fast
    2old2fast
    Expand Collapse
    Mar 25, 2010
    2,325
    486
    Gender:
    Male
    Occupation:
    sorta retired
    Vented cap will allow air in , vent allows air out , IMO you need both , no gas gauge will be fine till you run out .
    You'll have a short filler neck so you want a cap that vents in , or no vent at all so as not to spill gas...usually the " pressure relief" vent has a loop that goes higher than the tank to prevent spills , the end of the line should terminate above the tank to prevent a siphon ..
    #107 2old2fast, Nov 25, 2018
  8. 409T
    409T
    Expand Collapse
    Moderator
    Staff Member
    Jan 16, 2009
    1,791
    554
    Gender:
    Male
    Occupation:
    Retired
    My vent tube is just that, a tube that comes out of the top of the tank which allows air both in and out. I run the tube up in the air an inch or two then put in a 180 deg. bend and head it down toward the ground, ending in some inconspicuous place and add a non-vented cap.
  9. Gerry
    Gerry
    Expand Collapse
    Dec 31, 2009
    2,644
    600
    Gender:
    Male
    Not at all. My first version just had a hole in the tank cap as a vent.
    New one uses an anti roll over valve on the inside of the body. The vent pipe comes from the tank through the perch (the rectangular hole in the picture) into the body, and after the valve, then loops down and dumps through the floor. Just an extra safety precaution and to eliminate gas venting right behind me.
    G
  10. Indycars
    Indycars
    Expand Collapse
    Mar 11, 2010
    2,497
    1,104
    Gender:
    Male
    I agree with Gerry, add all the connections that you want now and in the future.
    I don't have a vented cap, but I do have a vent with brushes inside to stop any sloshing of the fuel into the vent. On the other side (exact same location) is the return line. In stead of running inside the frame, I used 3 MagDaddys that have a 50 lb pull strength to hold the line in place without drilling the frame. The MagDaddys have a 1/4-20 threaded extension.
    fletcherson likes this.
  11. rbsWELDER
    rbsWELDER
    Expand Collapse
    Dec 1, 2008
    822
    214
    Gender:
    Male
    Indycars - You may want to consider adding a roll-over valve in that vent line.
  12. Neshkoro
    Neshkoro
    Expand Collapse
    Jun 29, 2009
    1,487
    745
    Gender:
    Male
    Occupation:
    Retired
    The sad part is that if you roll over in your bucket, you're pretty much toast anyway.
    lincolnuT likes this.
  13. Pushrod
    Pushrod
    Expand Collapse
    Feb 20, 2018
    266
    151
    Gender:
    Male
    Occupation:
    retired
    Gruesome.....but true. ( But I still can't wait to drive that silly contraption)
  14. Pushrod
    Pushrod
    Expand Collapse
    Feb 20, 2018
    266
    151
    Gender:
    Male
    Occupation:
    retired
    My winter project goals lately have been to do something on the bucket daily, even if it's small. The windshield frame is ready for glass, some of the gauges are in the dash, the radiator shell is ready for paint and the gas tank has been mounted. IMG_1961.jpg IMG_1960.jpg IMG_1956.jpg IMG_1941.jpg
  15. Spanky
    Expand Collapse
    Jul 29, 2016
    3,018
    2,424
    Gender:
    Male
    Great progress, Pushrod. That's a handsome set of gages, and the gas tank looks cool! Capacity is 12 gallons if I remember correctly. Should be able to get you to the next gas station . . . :p:laugh:
    Pushrod likes this.
  16. Pushrod
    Pushrod
    Expand Collapse
    Feb 20, 2018
    266
    151
    Gender:
    Male
    Occupation:
    retired
    Not much progress to report these days, I've had the killer flu since the day after Christmas. I'm still not 100%, but managed to drop off my windshield to the glass guy this morning. I hope to get back in the garage next week.
    Spanky likes this.
  17. rubicon
    rubicon
    Expand Collapse
    May 28, 2007
    859
    254
    Gender:
    Male
    Just got done checking your post from beginning to the end. Like what I see so far. You're giving me the itch to start working on mine again. keep the pics coming.
    Pushrod likes this.
  18. 2old2fast
    2old2fast
    Expand Collapse
    Mar 25, 2010
    2,325
    486
    Gender:
    Male
    Occupation:
    sorta retired
    Bet next year you get a FREE flu shot !!
  19. Pushrod
    Pushrod
    Expand Collapse
    Feb 20, 2018
    266
    151
    Gender:
    Male
    Occupation:
    retired
    I get a flu shot every year, they aren't free by the way.
  20. Pushrod
    Pushrod
    Expand Collapse
    Feb 20, 2018
    266
    151
    Gender:
    Male
    Occupation:
    retired
    .Each year the CDC (Center for Disease Control) tries to predict (about 6 months prior to flu season) which types of flu are most likely to be the most infectious/acute/prevalent in the upcoming flu season. They choose 5 flu viruses and make up the flu shots based on those 5 only. There are many many more flu viruses out there that are NOT covered by the flu shot.
    #120 Pushrod, Jan 4, 2019
    Jim B likes this.
Share This Page
SSL Certificate
