Yes, I'm using a heim end. It didn't measure tapered. I'll drill it. Thanks.That is more than likely a tapered hole for a rod end. If you are using a heim end you need to drill arm out.
I get long bolts so I have a smooth shank to go in the holes then cut them so a thread or two is out of the nut.
Thanks. I was confused, too!Here's another link that gives dimensions. There's SO many sizes.
Shop Bolts » Shear Bolts
If I were needing a certain size I'd have to contact them. I don't understand the correlating numbers.
Hijack away, I'm all about learning somethingChop, I don't like to hijack someone's thread but I clicked on the Aircraft Spruce website. Where does it show the bolt size ( diameter and thread size)? Am I missing something or am I just too dumb to see it?
