Welcome to Our Community
Sign Up
Dismiss Notice
Bracing question
Discussion in 'Bodies' started by Tundrajax, Apr 2, 2017.
  1. Tundrajax
    Tundrajax
    Expand Collapse
    Apr 1, 2017
    38
    6
    Gender:
    Male
    Occupation:
    Coordinator, Department of Veterans Affairs
    I did a search and couldn't find anything. My question is when I start on making the floor and bracing the body of my 27 could I use carbon fiber strips or spectra carb? I have access to these materials at work and I can get what I need. Just wondering if anyone else used something different besides mat and chopped glass for bracing.
  2. Spanky
    Expand Collapse
    Jul 29, 2016
    3,020
    2,427
    Gender:
    Male
    I used plywood for my floor, firewall and behind the dash for good rigidity. I have no first hand experience with the materials you mentioned, but remember, the goal is not just strength, but rigidity. And it helps if fiberglass resin will adhere to whatever materials you use! (Don't ask me how I know . . .:rolleyes:)
    cooter likes this.
  3. Tundrajax
    Tundrajax
    Expand Collapse
    Apr 1, 2017
    38
    6
    Gender:
    Male
    Occupation:
    Sorry I should have explained better. I plan on using plywood for the floor and on the firewall but I was wondering if I could use the carbon fiber or spectra carb to join the body and wood together. Also spectra carb is fiberglass Matt sheet that has strands of carbon fiber woven through out it. We use both at work for making leg and arm orthotics and for prostetic sockets
  4. Gerry
    Gerry
    Expand Collapse
    Dec 31, 2009
    2,644
    600
    Gender:
    Male
  5. 2old2fast
    2old2fast
    Expand Collapse
    Mar 25, 2010
    2,325
    486
    Gender:
    Male
    Occupation:
    sorta retired
    ALA the resin [polyester or epoxy] you use is compatible to both products they should be fine
  6. butch27
    butch27
    Expand Collapse
    Nov 5, 2007
    2,493
    188
    Gender:
    Male
    Occupation:
    Retired
    I've used the plywood but I have notice that glass does not want to stick to the flooring ( it will encapsalate it) though. Just my opinion but it will pull away from the flooring in layers. No real problem.
  7. Tundrajax
    Tundrajax
    Expand Collapse
    Apr 1, 2017
    38
    6
    Gender:
    Male
    Occupation:
    Did you scuff up the wood before you laid the fiberglass??
  8. RPM
    RPM
    Expand Collapse
    Administrator
    Staff Member Forum Sponsor
    Oct 16, 2007
    5,072
    656
    Sand the wood with 36 grit the apply a good coat of just resin with a brush. The wood want to really absorb the resin, the lay the glass while the brushed on resin is still wet.
    cooter likes this.
  9. RPM
    RPM
    Expand Collapse
    Administrator
    Oct 16, 2007
    5,072
    656
    We Advan Tech for the floor
  10. rbsWELDER
    rbsWELDER
    Expand Collapse
    Dec 1, 2008
    822
    214
    Gender:
    Male
    I have used and recommend "The Woodpecker" to prep the wood.[​IMG]
    cooter and Tundrajax like this.
  11. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    Man, that things looks like a Medieval torture device.
    cooter and rbsWELDER like this.
  12. Tundrajax
    Tundrajax
    Expand Collapse
    Apr 1, 2017
    38
    6
    Gender:
    Male
    Occupation:
    I have something like this at work for putting holes in for a first lay up for a prosthetic socket
  13. Tundrajax
    Tundrajax
    Expand Collapse
    Apr 1, 2017
    38
    6
    Gender:
    Male
    Occupation:
    [​IMG][/IMG] [​IMG][/IMG] [​IMG]
    I noticed yesterday the light shinning through parts of the cowl. Should I reinforce with fiber strands now or wait till I reinforce the whole cowl with some wood ?
  14. Tundrajax
    Tundrajax
    Expand Collapse
    Apr 1, 2017
    38
    6
    Gender:
    Male
    Occupation:
    [​IMG][/URL][/IMG]
  15. Spanky
    Expand Collapse
    Jul 29, 2016
    3,020
    2,427
    Gender:
    Male
    I say, wait! Most of what you are seeing will probably be covered up in the process of adding wood to your cowl.
Share This Page
SSL Certificate
