Welcome to Our Community
Sign Up
Dismiss Notice
Brake Lines
Discussion in 'Brakes' started by T-Bucket Bob, Jan 2, 2017.
  1. T-Bucket Bob
    T-Bucket Bob
    Expand Collapse
    Feb 5, 2008
    189
    43
    Gender:
    Male
    What are you guys using for brake lines?
    T-Bucket Bob
  2. choppedtop
    choppedtop
    Expand Collapse
    Jan 10, 2014
    1,933
    637
    Gender:
    Male
    Occupation:
    Retired
    3/16" steel line. I used AN fittings on all connections where possible. If I do another, I will use the newer copper/steel lines (if that is the correct name) because they form much easier than the standard steel lines. I would stick with the AN fittings.
  3. Gerry
    Gerry
    Expand Collapse
    Dec 31, 2009
    2,647
    605
    Gender:
    Male
    I have Earls throughout. No solid lines anywhere.
  4. EX JUNK
    EX JUNK
    Expand Collapse
    Moderator
    Feb 5, 2008
    2,997
    516
    Gender:
    Male
    Occupation:
    Retired electrician
    I used 3/16" stainless tubing and stainless flex hose at the wheels with AN fittings.
    JetMech727 likes this.
  5. 409T
    409T
    Expand Collapse
    Moderator
    Staff Member
    Jan 16, 2009
    1,800
    557
    Gender:
    Male
    Occupation:
    Retired
    All stainless steel braided.
  6. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    Did you guys make your own lines of the longer runs?
    -AN 3?
  7. EX JUNK
    EX JUNK
    Expand Collapse
    Moderator
    Feb 5, 2008
    2,997
    516
    Gender:
    Male
    Occupation:
    Retired electrician
    I made all the cuts and bends on my lines.
  8. Spanky
    Expand Collapse
    Jul 29, 2016
    3,086
    2,527
    Gender:
    Male
    Used pre flared NiCopp lines on mine - easy to bend by hand.
    tfeverfred likes this.
  9. Gerry
    Gerry
    Expand Collapse
    Dec 31, 2009
    2,647
    605
    Gender:
    Male
    Yep with Earls fittings. Did have the end of the lines swaged where they meet the calipers.
    This is the fitting thro the frame. Used a SS Button hed drilled to take the plastic liner
  10. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    Now that's cool.
  11. tbucketlar1
    tbucketlar1
    Expand Collapse
    Jul 2, 2016
    35
    0
    Gender:
    Male
    Could you give more info on Earls brake lines. Thank you in advance
  12. Intrepid
    Intrepid
    Expand Collapse
    Mar 31, 2016
    542
    154
    Gender:
    Male
    Occupation:
    Aircraft Electrical Engineer (Avionics)
  13. Tjbucket
    Tjbucket
    Expand Collapse
    Feb 16, 2016
    259
    53
    Gender:
    Male
    I used 3/16" steel line and AN#3. You can see how I ran it from the master. Just in front of the master I routed the line on the bottom side of the frame rail up to the front wheels which tucks just to the inside of the frame rail and used a stainless through fitting and ran stainless braided to each caliper. On the rear, at the rear bottom frame rail, I ran another braided line to the differential to a "T", and steel line out to each drum along the axle tubes. It is very well hidden and brakes work well. Tried to load a pic of the front but, for whatever reason it keeps telling me file too large.......sorry. All lines were hand bent and flared. I can only imagine what a pain flaring stainless would be. I did use a line pliers for tighter bends. You can just see where the line runs across the trans cross member to the right front wheel.
    rbsWELDER likes this.
  14. brendonn
    brendonn
    Expand Collapse
    Apr 9, 2017
    12
    0
    Gender:
    Male
    I also used 3/16" stainless tubing, and have no issues whatsoever.
  15. bamabucket
    bamabucket
    Expand Collapse
    Jul 27, 2009
    114
    41
    Gender:
    Male
    Occupation:
    Retired
    I used NiCop for the hard lines and braided stainless flex lines at the wheels and connection to the differential with all AN fittings. I had never installed any hard lines before and am very glad I used the NiCop because of the ease of bending and flaring. It looks like copper tubing but is not and meets all the standards for brake lines.
  16. 409T
    409T
    Expand Collapse
    Moderator
    Staff Member
    Jan 16, 2009
    1,800
    557
    Gender:
    Male
    Occupation:
    Retired
    I just saw your question. No, I either bought the correct length lines or had them made. Its been too long so I don't remember which but they are 3/16" lines.
  17. skinny mike
    skinny mike
    Expand Collapse
    Jun 25, 2018
    140
    13
    Gender:
    Male
    Occupation:
    retired.
    brake lines...what the hey! Am redoing the lines on an old someone elses build that I bought. The only 3/16 lines I can find locally have metric fittings. I can get 1/4 in. lines with US fittings. Don't want to buy a coil and fuss with straightening. Soooo, buy the ones with the metric ends, cut-em, toss the fittings and use US ones and reflare? I,m guessing that 1/4 in. is too large. Am I right? Sigh!
  18. skinny mike
    skinny mike
    Expand Collapse
    Jun 25, 2018
    140
    13
    Gender:
    Male
    Occupation:
    retired.
    OOPS ..sorry! Didn't mean to highjack. Forgot how to post NEW thread. Can't think.
  19. choppedtop
    choppedtop
    Expand Collapse
    Jan 10, 2014
    1,933
    637
    Gender:
    Male
    Occupation:
    Retired
    Speedway carries lots of different lengths that are 3/8x24. Don't know if you have Napa there, but they have them also. If some were a bit to long, you could cut them and reuse the fittings.
  20. 2old2fast
    2old2fast
    Expand Collapse
    Mar 25, 2010
    2,325
    486
    Gender:
    Male
    Occupation:
    sorta retired
    Napa can get whatever you want next day around here .......
Share This Page
SSL Certificate
