The Hustler
The two wires from the hydraulic brake light switch pulled out of somewhere and I don't know exactly where. I found one of the wires pulled out of a connector to a wire going to the turn signal lever on the steering column. I believe the other wire (which is black) goes to ground. Could this be right?
Long as I'm on here, my wiring is a real mess, (not my doing) so I'd like to rewire the entire bucket. Is the wiring harness sold by Speedway the way to go? Has anyone used one ?
Thanks y'all.
Thanks y'all.
