fletcherson
I have seen various ideas about how to figure weight ratings on springs and about different materials between the leafs. My T has buggy type springs front and rear. Neither have any anti friction pads. I plan to initially re use them, I may go to coil over on the rear, but as an upgrade. The front will most likely be permanent. I will remove a leaf or shorten or whatever to make them deflect to hopefully provide a decent ride and they obviously must be lubricated in some way to have a chance of functioning. Anyways, my post is looking for opinions on what you think is the best material to use for spring pads between the leafs. They are radiused and chrome, so I would prefer to use a non friction type material instead of grease, but I want them to function as well as possible. Also how many leafs are you guys running? I am also planning to add pan hard bars, front and rear, not that it should matter to this subject, just a point. Another thing I have pondered, my car has the buggy spring on the rear and coil over shocks, which is overkill. I presume it was due to wheel stands, etc as the car was primarily a drag car, but do the buggy springs on the front and rear provide lateral stability as far as maintaining a level stance side to side? What's your thoughts? If they are problematic and will require attention, I would prefer to plan it sooner than later while the car is in re design mode. Keep in mind that I am trying to keep it as close to its original form as I can for nostalgic purposes, but it must be safe, functional, and pleasurable to drive or what's the point? I am going to remove the old coil over shocks on the rear no matter what I end up doing long term. I planned on initially retaining the buggy spring and replacing the coil overs with shocks, but I have considered putting modern coil overs on it and either retaining the main buggy spring for differential positioning, or just removing them entirely and relying on the pan hard bar for position. It has lift bars and radial arms as well.
