To shock, or not to shock? That is the question! Whether it tis better. . ...
These are the friction shocks I made for my bucket. Seems like they are very similar to what @Hackerbilt made. This should give you a good idea of the spring setup he used. For mine I used a slant six valve spring and retainer. I searched a lot of threads across the internet on friction material and am giving this UHMW plastic a try. The reason people were suggesting this on the forums was the material has less static friction so it will result in a smoother operation. I may try some other materials this season though. Unfortunately my long shock arms probably don't help either so maybe some stiffer material like rubber would help. I eventually welded tabs to the spring shackles for the mounts.
That is a robust setup! Thank you for sharing. Every little bit helps to foster ideas if not outright copy somebody!
Same exact idea...only you used two arms and 1 mount, while I used 2 mounts and 1 arm. I always liked 1/4 elliptic springs. Mine had a cross spring...but I'm willing to bet 1/4's offer better movement. Maybe in the future I will get to try a set. I'm toying with the idea of building another car. I really miss my old bucket.
Looks good! How hard is it to move up and down? I used ‘40 ford brake adjuster springs back in the day. They were real thick and very strong.
Awesome. That’s the thing I love about these kind of cars and sites: the creativity and ingenuity demonstrated in creating them out of necessity or just being not “off the shelf”. Plus the various materials, designs, etc, pass or fail, that we share. I imagine old school (think: slide rule) think tank engineering groups might have been like in the early, true golden era of mechanical design. Let’s share our experience and resources related to chrome: faux, home brew, or out sourced... seeing those shiny pieces reminded me of the lack of local quality and affordable options.
Excellent points
